0 members (),
174
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Recently got my 41' fired up. It runs great,,, once you get it started. This, so far requires a shot of starter fluid in the carb.I'm assuming that the accelerator pump is not working? I haven't pulled the carb apart yet so my question is, does it have a accelerator pump or is there another issue like I just don't know how to start it? It has a throttle knob and a choke knob on the dash is there some technique to start that I don't know about? Any help would be appreciated, best place to source a rebuild kit if needed? Thanks. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | First pull it off and I'd it is there any tag or I'd #?... A pic would be nice too.
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Choke and spark should start it.Is the choke cable hooked up?. Before you pull the carb, look down it and work the throttle linkage and look for fuel squirting. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Is this your COE? Updrafts are different than regular carbs and are very simple to work on.
If you haven't pulled the carb off the truck before, it's probably full of dirt or crap from years of accumulation. Before diagnosing carb problems your best bet is to rebuild it and start from there.
When reinstalling be sure to put a fuel filter inline to the carb.
Jeff | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Ya it's the COE. It runs really good, just don't know if it has a pump? Sounds like it does. I'll pull it off and investigate. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | If it is a Zenith carb, it probably has a VACUUM accelerator pump!
While I dislike the word "never"; one should NEVER pump the footfeed on a vehicle with an updraft carburetor! Guess where the fuel goes? The vacuum accelerator pump prevents this, as it will only function after the engine is started, and manifold vacuum has been established.
A vehicle with an updraft carburetor should ALWAYS be started using the choke.
The Carter BB-1 does have a mechanical accelerator pump, so the onus is on the operator NOT to use it.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Thanks for the replys. This gives me some valuable info that I needed. I'll try to start it with the choke only and keep my foot off the pedal. If that doesn't work I'll look into the carb some more. Do you have to use the choke even after it's warm to increase the vacuum? | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Thanks "carbking",it appears that I just did not know how to start my own truck? I did not touch the pedal, and just held down the plunger longer and she fires right up! Thank you for the correct technique, as I would be tearing the carb down by now to find nothing wrong. I didn't think about the whole updraft system, just trying to start her like an old V8? Ooops. | | |
