| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 20 | Hello there,Can anybody tell me where I should install a low pressure brake switch at? I am running a Corvette style master mounted below the cab. Disc on front, drums on rear. A 2 lb residual valve for front brakes and a 10 lb for rears. Then behind the rear valve I have an adjustable preportioning valve. I'm thinking it should be installed ahead of any of those inline valves. Can I get some thoughts from anyone? Thanks PS I have a Painless switch part #80174 | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Yes, the switch should be install before the residual valves. Some switches will tell you not to put them after the valves. Root | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Why not try another path. After several pressure switch failures I did. The pressure switch is not really rated to handle the current necessary to run regular brake lights, especially six volts. I went with the mechanical brake light switch made by Lokar. Easy install with no cuting into the brake lines.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Instead of running your lighting load through the the switch, just use the switch to trigger a relay. | | | | | Joined: Feb 2000 Posts: 5,210 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,210 | I found on my truck, I could stop with a light foot and never turn on the brake lights, so I installed a heavy micro switch to the pedal assembly which turns on the lights as soon as the pedal moves. I have read on the HAMB web site about brake switches and pressures. Seems there are different pressure switches which react to higher or lower pressures. Most thought the low pressure switches worked quicker but don't last very long due to higher pressures required for disk / drum setups. The high pressure switches last longer but take a heavy foot to trigger them. The best way was pedal mounted switches which work with movement. No matter how easy or hard you are on the pedal, the slightest movement activates the lights. I installed two pressure switches on mine before switching over, I thought the first one was bad since I could stop with out activating it.
Joe | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | A brake light switch for a mid sixties F... product will work fine if you need to activate the brakes light with a hydraulic switch.
I've used them for years on various projects and had very good results. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | A Harley Davidson motorcycle pressure switch works well since the lights are activated with very little pressure and they work well with silicone brake fluid becuse that is the fluid installed in Harleys out of the factory. You can pick them up new at any good Harley dealer.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | A Harley Davidson motorcycle pressure switch works well since the lights are activated with very little pressure and they work well with silicone brake fluid becuse that is the fluid installed in Harleys out of the factory. You can pick them up new at any good Harley dealer. I'll second this....although the H-D switch you will pay for. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here's a NO pressure switch. You didn't say what year you need it for but if up to 55 you may as well use the original, they work really well. http://www.oldchevytrucks.com/cart/product.asp?prodid=EL106&i=9766||||| | | |
