2 members (3B, Cosmo),
149
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | My Kobalt brand compressor is about 3 years old. A few months ago it began leaking oil (mineral) from the pump base and drain plug & valve. These were wiped clean, retightened and oil added to specs. given in the owners manual. It took about 7 ounces to fill. Since then this process has been repeated. It seems odd that oil would get down into the tank. Bad seal(?) Any ideas???
Also why is mineral oil specified instead of light weight motor or synthetic oil? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Mine did the same thing from the drain plug. It dribbled all over the place and I thought it must be coming from all over. Nope, just the drain plug. Just add a little teflon tape or gasket sealant to the threads and you should be okay.
Mine specified a synthetic only. Not sure why mineral oil?
Jeff | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....and mine has a sight glass and leaked there...it looked like it was leaking everywhere. I ended up making my own small gasket and tightened it up good..but careful not to break the glass. And as mentioned, a little Teflon will help with drain plug. These compressors run a lot and with even the slightest vibration will eventually need "tightening up" of stuff. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Compressors vibrate. Aluminum block ones more so than the old heavy cast iron ones. The old ones began to leak after many years. The new ones leak a lot quicker. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Thanks, guys. This one has a sight glass too, which was loose, as was the bottom plug. I added Teflon tape tightened all fittings, added oil and the leaking stopped for about 2 days. I think I'll try gasket sealer, when I get a chance. Ha-- the leaky Stovebolt must have infected the "kobalt". | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | The gasket sealer worked!!! Teflon tape appeared to have disintegrated.
I decided to use synthetic oil instead of the mineral oil referenced in the OM. As I understand it they are similar. After a week of use, so far so good. | | |
