5 members (Southerntruck, RoadsScholar, 50Chevy3100, NorthCoast3800, Gray_Ghost), 118 guests, and 3 robots.
Topics128,100
Posts1,056,514
Members48,448
Junior Member
Junior Member
Now I'm trying to get ideas on the best kind of subwoofer to fit into my truck.
Its a '52, it has the original bench seat and gas tank behind the seat. So what I need is to find a way to put in a bass of some kind either under the seat or behind the seat above the gas tank.
Has anyone else found something suitable?
I have been considering Bazooka 6 or 8 inch tube subwoofers with a built in amp. But I still have to measure what kind of space I will have and compare it to the size of the subwoofers.
Anyone elses experience with this would be welcomed.
I
I Offline
Just drive behind any modern coupe with teenagers in it and you shouldn't need your own sub.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
try a radio shack store.
Jim & Caroline
Quote
[snicker]
Crow,
A tube sub will probably be your best bet.
Finding a tube sub that'll fit is probably the best way to go.
I suppose you could build a custom sealed enclosure to match the specs of the specific speaker you use, then power it with a seperate amp, but my guess is you aren't going to compete in sound pressure contests.. you probably just want a little bottom end to your music to help fatten out the sound.
Just remember these old trucks tend to rattle.. the more bass you add, the more you'll be chasing down rattling pieces of the truck.
Junior Member
Junior Member
I've narrowed down some products that would work nicely in these trucks. Anyone interested in adding some bass to your system, check out these small subwoofer options.
Kenwood KSC-SW1 or KSC-WA62RC
Infinity BassLink
Clarion SRV303
These should be small enough to fit behind or under a bench seat. And not too big to be annoying the neighborhood.
