0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93067 10/05/2005 7:31 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | Now I'm trying to get ideas on the best kind of subwoofer to fit into my truck. Its a '52, it has the original bench seat and gas tank behind the seat. So what I need is to find a way to put in a bass of some kind either under the seat or behind the seat above the gas tank. Has anyone else found something suitable? I have been considering Bazooka 6 or 8 inch tube subwoofers with a built in amp. But I still have to measure what kind of space I will have and compare it to the size of the subwoofers.
Anyone elses experience with this would be welcomed. | | |
#93068 10/05/2005 8:17 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Just drive behind any modern coupe with teenagers in it and you shouldn't need your own sub. | | |
#93069 10/05/2005 8:59 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#93070 10/06/2005 2:38 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Inky05: Just drive behind any modern coupe with teenagers in it and you shouldn't need your own sub. [snicker] Crow, A tube sub will probably be your best bet. | | |
#93071 10/06/2005 3:04 PM | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Finding a tube sub that'll fit is probably the best way to go.
I suppose you could build a custom sealed enclosure to match the specs of the specific speaker you use, then power it with a seperate amp, but my guess is you aren't going to compete in sound pressure contests.. you probably just want a little bottom end to your music to help fatten out the sound.
Just remember these old trucks tend to rattle.. the more bass you add, the more you'll be chasing down rattling pieces of the truck.
#93072 10/18/2005 2:37 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | I've narrowed down some products that would work nicely in these trucks. Anyone interested in adding some bass to your system, check out these small subwoofer options.
Kenwood KSC-SW1 or KSC-WA62RC Infinity BassLink Clarion SRV303
These should be small enough to fit behind or under a bench seat. And not too big to be annoying the neighborhood. | | |
