2 members (festerhairball, fonz8261), 50 guests, and 5 robots.
Topics128,093
Posts1,056,046
Members48,433
#929598 03/22/2013 12:43 PM
I am now in the mid stream of refinishing the gauge's. I drilled out the aluminum rivet the holds the face plate to the gauge works with 5/64" drill bit. I will redrill the holes with a #44 drill and use #2 machine screw and nut to reassemble. With my thick farmer fingers, this is tweezer work.
The pointer or needle is painted some off-white color, it seams to have a green tint. Did these original needles glow or luminous in the dark? What color or paint have you used? All opinions on this issue will be appreciated.
Woodie
Doubt they were luminous...supposed to be lighted by small bulbs in the back.. Mine, however, don't even have the bulb fixtures. In both the gauge cluster and spedo I think there were five bulbs in all...
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
In my 55 series 2 the needles were all a light green color like the glow in the dark stuff...although they dont glow. I'm a VW restoration shop and simply used some 1966 VW bahama blue (which really isnt blue) that I had in stock. It was almost perfect.
If I wouldnt have had the paint Id have just picked up some rustoleum fusion or krylon in a similar color.
Leo Offline
Moderator
Moderator
I don't know what year your truck is, but my needles are white. I just used some white-out, easier than spray painting.
'51, 3100 AD, I always forget. White out, sounds easier when a rattle can.
Woodie
....and I use Appliance White
