1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92860 09/02/2005 4:12 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Hey there, y'all ...
Anybody know of a source for supplemental LED lighting (brake and turn) that will work with six-volt systems?
Apparently the folks at "thirdbrakelight.com" are history...(?)
Am hoping to find some LED "light bars" that I can "hide" around the top of the rear windows of my old cars and trucks for "high-mount" stoplights...
Thanks for any leads !
Frank 54
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#92861 09/02/2005 5:29 PM | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | Hey Frankie, I thought that it was "Yens" in PA, and "Y'all!" in Texas.
Other than that, I have no leads on aux LED tail lights. :-) | | |
#92862 09/02/2005 6:56 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Y'ens or "you-uns", or y'uns is Western PA...Pittsburg & such...
How's the "Caw-fee" there in Englishtown? (LOL)
Guess PA is LED-free...
#92863 09/02/2005 7:08 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I might be wrong, but I thought LED's worked with either 6 volt or 12 volt. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#92864 09/02/2005 8:09 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Y'ens or you'ns is Pittsburg talk... In scranton Y'all isn;t right either... It's you's. | | |
#92865 09/02/2005 8:14 PM | Joined: Mar 2005 Posts: 10 Junior Member | | Junior Member Joined: Mar 2005 Posts: 10 | Work on both 6 and 12 volt systems, as they are current devices. Operate a little brighter on 12 volt. Pro's 1st Choice Canada would be a place to look. | | |
#92866 09/02/2005 8:51 PM | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | The "Caw-fee" is fine, but that is more Northern NJ, NYC, Southern NY, and Wetern Long Island. "You'se Guys" is the official NYC expression for "Y'all."
Englishtown is loaded with ex-NYC people, myself being one of them, we can determine the local farmers from the new ex-city folk right away. Caw-fee is one way, the other way is that the farmers are driving around in new pick-ups, while the ex-city folks are driving MB's and BMW's. | | |
#92867 09/02/2005 9:14 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | It always souded more like "Quaw-fee" to me. | | |
#92868 09/09/2005 5:51 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Inky's right...NE folk say "you's" (or "youse")... But I'm not from around here... I've been using "y'all" forever, even though I might not be "geographically justified" in doing so, growing-up in suburban MD, but then I can't talk like the natives do in Baltimore (and I've actually TRIED ! :o ) Well, I'll get a sample 12-volt LED and see how they work on my six-volt iron... How about polarity senstivity? Do they care about Positive ground vs. Neg ground? (Thinking of my old MoPars and GMCs)...
#92869 09/10/2005 1:28 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Yes, LEDs are polarity sensitive. | | |
#92870 09/12/2005 6:25 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | And I know from experience....if you hook em up backwards, it fries the light instantly....oops. I was testing an LED light on a battery and learned the hard way...luckily, the light was POS i was just messin with | | |
#92871 09/12/2005 8:38 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | | | |
#92872 09/15/2005 6:28 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Actually, if you hook LED's up backwards they just don't light up. They won't be damaged. They are diodes, they only conduct current in one direction. The block it the other way.
#92873 09/15/2005 5:37 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | I would suggest checking with this company. They show 12V units in the correct shape and may be able to supply 6V. LED Lights Paul | | |
#92874 09/16/2005 1:23 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Whether the diodes will blow or not when hooked up in reverse depends on the PIV rating, but I doubt that it would be lower than the peak voltage of a six volt system. | | |
#92875 09/16/2005 3:25 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Well if that's the case 'google up' podlights and hyperlite (not the wakeboard). or I'll pass along some sites::: + http://store.tireflysonline.com/podcar-red.html + http://xtrasrally.com/hyperlite.htm + http://www.webbikeworld.com/Motorcycle-technical-articles/halogen/ + http://www.customdynamics.com/louver_led_accent_motorcycle_lights.htm I made a fitting inside the stock taillight assy and glued in three podlights ~ brake ~ tail ~ blinker and will get more light from the 6 podlights now than any stock tail light. The pod lights (usually cost $20) were cheap enough that I bought a bunch and used them on my olde bikes also. I also added a third standard double filiment clearance brake light below the tail gate in the middle. hyperlites are not so cheap. Ps Paul I believe those haywire are only brake/ tail... NO blinker. you can also buy at auto parts a halogen light bulb that's brighter + http://www.sherco-auto.com/minilamp.htm hope it helps + Pss frank54 I was born in wilkinsburg and don't say any of those things... course I moved to (NOW) ugly calif when I was 5.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#92876 09/22/2005 6:09 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | As said before, LEDs are Light Emitting Diodes. They allow current to flow one way (unless you exceed the reverse breakdown voltage, then they go POP). LEDs typically turn on when they are exposed to 1.7 volts (across the terminals of ONE Led), which we normally round up to 2 volts for most circuits. If you know that, then you know that the maximum number of LEDs in a 6 volt system would be 3 in a series configuration. In a parallel configuration, you can add togther a number of 3 LED strings to get the amount of LEDs that you want - they will just consume more current than a single string (but likely less than a normal 6 volt bulb).
What you need to find is a company that is making LED lights with 3 LEDs in a string. Most companies will tend to make 6 LED strings (12v) because of the 12 volt standard.
It COULD be possible to convert a 12 volt LED light to a 6 volt light, provided that the circuit bord isn't potted in a plastic resin (to prevent you from gaining access to the circuit wiring). You would cut the 6 LED strings into 3 LED strings, and move the power and ground leads appropriately. | | |
#92877 09/23/2005 9:15 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | How about the turnlight? Will the LEDs suck enough current to work the blinker relay? | | |
#92878 09/23/2005 4:04 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Vaughn,
Thanks for your detailed reply...so far, it looks like I'm going to be making my own...
I'm trying to come up with LED-based stuff to use as supplemental lighting for brakes and turn signals on a variety of six-volt vehicles, Bow-tie and other makes...
So, are there special high-output LED's I should be looking for, or can I just go down to Radio Shack and buy a bunch of red LEDS and some perf-board and go to town ?
#92879 09/23/2005 4:58 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Stovebold,
They don't draw enough current to allow the type of blinker that doesn't blink when one of the lights is burnt out to flash, but an emergency flasher unit should work. | | |
#92880 09/24/2005 1:02 PM | Joined: Sep 2003 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 23 | There are units marketed to the street rodder realm called "no load flashers". They are meant for use in place of the standard flasher when LEDs are used. That conversion is really getting hot.
#92881 09/24/2005 8:12 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Frank54: can I just go down to Radio Shack and buy a bunch of red LEDS If generic off-the-shelf LEDs are going to work, and I think they will, check a place called All Electonics ( www.allelectronics.com) before you go to Radio Shack. Standard red are 10 for a dollar up to 100. After that 7 cents each to 1000, and 4 cents each after that. Buy $40 worth and have fun!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#92882 09/27/2005 2:29 AM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Well, I'm sorry to say that generic LEDs won't work well. Until recently, LEDs could not put out enough lumens (candlepower) to be seen under all conditions. In addition, LEDs did not have a wide enough angle of dispersal (you cannot see the light they put out if you are too far to the left/right of the LED). LEDs used in automotive applications are of a special type. You would need to contact an electronics parts house and have them help you select the right LEDs.
I used to do a little design work with LEDs, at that time Stanley LEDs were usually the best in the market. | | |
#92883 09/27/2005 7:59 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Old Sub, Vaughn, et al...
Thanks for the suggestions...I went to the Allelectronics.com site and found loads-o-stuff, including some SUPER-bright red LEDS...
I think I'm a gonna git me some perf-board and some LEDs, and once I find the the proper series combo for 6-volt application, I think I'll build me some custom supplemental signal & brake lighting...
Will let you know how I make-out!
Regards,
Frank 54
#92884 09/30/2005 3:10 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I installed two-function sockets (with turn signal and parking) in my '48 sometime ago. I put some of that amber plastic in there since I thought the turn signal was easier to see but it's still a bit on the dim side.
Could I put some LEDs in parallel with the existing 6v lamp? Seems to me that would give me more light and the turn signal would still work since the 6v lamp is providing a load?
Thanks! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#92885 10/25/2005 7:20 PM | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | I know this ebay link won't be here forever but this is what you need ( http://cgi.ebay.com/New-50-Ultra-Br...9610QQcategoryZ66952QQrdZ1QQcmdZViewItem ). After this link dies, just search on ebay for "Bright White LED" and you'll find all the 10,000 mcd LED's that you can shake a stick at. (And don't ask me why so many folks go around shaking sticks at LED's) Just use the white ones and let your lenses do the coloring. Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
