3 members (Bill Hanlon, 32Fordpuchoptop, 1 invisible), 103 guests, and 2 robots.
Topics128,049
Posts1,055,635
#927960 03/16/2013 2:13 PM
I'm a new owner of a 54 3100. From the casting number it appears that the motor was swapped and I have a 62 235. After browsing the stovebolt pages for the past three months and I decided to tackle my first project, changing the rear main seal. After dropping the oil pan I was looking in the bottom to see if any sludge had built up and I found this metal clip, see pic? Can anyone help me identify the part?
http://i1352.photobucket.com/albums.../IMG_20130316_114215_965_zps50cd100f.jpg
Thanks in advance for any help
RobZ
Can't do anything with that URL. Try submitting it as a link.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Chinese sabotage! (Don't know the Chinese word for the French word sabotage). Maybe previous mechanic was cleaning that piece on his bench grinder with a wire wheel on it and it flew off like half of everything I try to clean up on one of those "parts slingers" and ended up inside the disassembled engine. I'll bet he is still wondering where it went.
52Carl #928028 03/16/2013 7:52 PM
Y
Y Offline
"Toggle" bolt bar? Can't imagine how it could have gotten inside the oil pan!
That "M" indicates it's Motormite part, probably part of a replacement drain plug used if the threads are stripped out of the pan. Works like a toggle bolt.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Could some one have put a rubber expansion plug in where the draft tube would normally be? Some did that when they would attempt to put a PCV system on their truck.
Sure looks like the toggle end of a toggle bolt to me....
Thanks to everyone, my guess was a toggle bolt also. My only problem where it came from? The oil plug was not stripped and the draft tube is still installed. Well I guess I will continue on with the rear main seal and not worry about it for now.
Thanks again
RobZ
54_Rookie #928193 03/17/2013 11:44 AM
Must have come from that Datsun the truck gobbled up on the highway. grin
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
54_Rookie #965038 08/19/2013 12:25 PM
RobZ,
Interesting find in your oil pan. It was great meeting you this weekend. Drop me a PM.
David G
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
54_Rookie #965289 08/20/2013 10:16 AM
Z
Z Offline
The only thing I can think of where that may have came from is out of another guys shop. So many rebuilders throw all the parts they have to every engine in one pile. This is perfectly fine but mabe they guy filled the pan with parts and did not get them all for some reason. If you are throwing all your parts in one pile like that always make sure you have everything. If I were you I would pull the valve cover and side cover just in case there are more surprises.
My money is that it got caught under the sheet metal baffle and was just over looked. Never got in the way of any thing moving so lucky you. Put a nail through it and hang it on the wall to remind you to look at every thing before you install it. You can learn from the other guy's mistake and not have to pay the admission price. smile
Steve H
