0 members (), 115 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#927996 03/16/2013 5:21 PM
On a project truck I have with a Carter YF carburetor I have a stumble coming off idle when I accelerate. It's noticeably worse when the motor warms up. Once I get past that it runs cleanly and drives well.Points and timing are good and the vacuum advance works properly so I thinks it's the carb. The idle bleed screw is set spot on also. One other thing I'll mention is that the fuel mileage is not good for a small six. All this leads me to believe that the float level may be too high but I haven't had it apart yet and don't have the specs to set it.
I'm looking for suggestions on this and a ya or nay on my float level idea.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
sleeve #928037 03/16/2013 8:30 PM
I would check the accelerator pump circuit, make sure it has a good squirt of fuel. Check it with the egine shut off.Remove your air cleaner, and look down the carb with a good light, mash the throttle and look for fuel coming out of the accelerator pump circuit
sleeve #928286 03/17/2013 5:50 PM
I checked that and I'm getting enough fuel from the accelerator pump, one more thing to cross off the list. Thanks for the input!
