| | | Forums66 Topics128,091 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | On a project truck I have with a Carter YF carburetor I have a stumble coming off idle when I accelerate. It's noticeably worse when the motor warms up. Once I get past that it runs cleanly and drives well.Points and timing are good and the vacuum advance works properly so I thinks it's the carb. The idle bleed screw is set spot on also. One other thing I'll mention is that the fuel mileage is not good for a small six. All this leads me to believe that the float level may be too high but I haven't had it apart yet and don't have the specs to set it.
I'm looking for suggestions on this and a ya or nay on my float level idea.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | I would check the accelerator pump circuit, make sure it has a good squirt of fuel. Check it with the egine shut off.Remove your air cleaner, and look down the carb with a good light, mash the throttle and look for fuel coming out of the accelerator pump circuit | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I checked that and I'm getting enough fuel from the accelerator pump, one more thing to cross off the list. Thanks for the input!
