3 members (homer52, Bill Hanlon, 1 invisible),
140
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | I purchased new lumber today for the flat bed on Brutis, my '66 C60 two ton. Now, my problem is that I don't know which stain color or product I should use on the wood. Any Ideas??? | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Did you buy treated or un-treated lumber and what kind (oak or pine, etc.)? I had treated lumber on my car trailer floor that lasted 25 years with nothing put on it and it sat outside all the time. Mike B  | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Hello Mike. I bought un-treated pine. This truck will be stored inside and probably not driven in the rain much. I plan on using it though for hauling stuff, (after a few ATHS events). I was thinking about using the same type of stain I used on my deck. Maybe a redish color. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I guess you need to decide whether you want a finish over the stain. Stain products that are meant to provide complete protection would probably not work under a clear finish. | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | I'm not sure, LOL... I was thinking about using a stain that offered complete protection. Perhaps I should take a trip to the hardware store and do some research, LOL....I didn't want to use a clear coat finish since I will be doing some hauling in the future. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | I think any stain made for decks would be fine. After a few years if it needs to be freshened up, pressure wash it, let it dry and apply another coat and it's as good as new. I wouldn't use any clear, just stain in whatever color you like! Semi-transparent will show some of the wood grain, solid hide will not and will give a more uniform color. Mike B  | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Hello Mike B. Deck stain is oil based isn't it? As you can tell, I know next to nothing about stains and paints, LOL. Oil should soak in well for good protection on pine shouldn't it? I used a Behr product on my deck last summer. I'm thinking about using that on the bed wood. Thanks! | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | I built my bed with purple heart. I leave the truck outside. It has been almost 4 years since I built the bed. Its in great shape. I use Watco Exterior Wood Finish. http://www.rustoleum.com/CBGProduct.asp?pid=47 | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,Mt. Tam Trucker! last Summer,there was another discussion on this topic. someone suggested Spar varnish,but no one ,(as far as I remember),informed us on the quality or longevity,of any given product. Well-Done!! Thanks,again! Watco Ext. Wood Finish, should work well on white oak, too,don't you think? | | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | Used motor oil, I used it on the pine deck of my 46. It is free and you will never run out of it. Every so often throw some oil on it and mop it around. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Spar varnish is a very poor choice for the high elevation UV rays. It doesn't work well at all. Use a commercial wood preservative and coat it several times letting it soak in between applications. Motor oil works OK but isn't pretty and gets all over the cab interior. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks for clarifying,Dave! I know spar varnish was suggested on a different thread,last Summer. I don't know how it would hold-up,though. Again,thanks for the help. | | |
