6 members (JW51, dt235sd, Barney1951, Bill Hanlon, 55shaker, 1 invisible), 44 guests, and 4 robots.
Topics128,176
Posts1,057,121
Members48,463
#922295 02/23/2013 3:51 PM
b10
Offline
I will only be driving around town maybe 2-3 miles down and back maybe twice a month.I would like to run it hotter is this ok or not .Feed back ,please.
Go with the 180 I think you will find your trucks new nickname to be "puddles" with the 195. JMO!
b10
Offline
( no puddles )just my twisted brain thinking to hard.
2-3 miles is hardly enough to let it warm up, let alone get "hotter" - a thermostat sets the minimum temp the motor can run, a 180 is plenty unless 'betsy' is a later model small block wink
I used a 195 in my truck for 25 years, never had a problem.
If your vehicle is 50 or 60 years old, it will take more than a couple of miles to warm up no matter what kind of thermostat you have. Over 50 years ago when I drove a 50 GMC to school, I used to put a piece of cardboard in front of the radiator, but I didn't expect much heat until after a couple of miles.
B Online: Content
Most of these old rigs hold way more coolant than newer rigs thus takes more time to get all that coolant up to temp., be it 180 or 195.
BC
1960 C60 pasture art
