3 members (50Chevy3100, 2 invisible),
64
Mod | | | Forums66 Topics128,180 Posts1,057,145 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | I will only be driving around town maybe 2-3 miles down and back maybe twice a month.I would like to run it hotter is this ok or not .Feed back ,please. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Go with the 180 I think you will find your trucks new nickname to be "puddles" with the 195. JMO! | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | ( no puddles )just my twisted brain thinking to hard. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 2-3 miles is hardly enough to let it warm up, let alone get "hotter" - a thermostat sets the minimum temp the motor can run, a 180 is plenty unless 'betsy' is a later model small block  Bill | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I used a 195 in my truck for 25 years, never had a problem. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If your vehicle is 50 or 60 years old, it will take more than a couple of miles to warm up no matter what kind of thermostat you have. Over 50 years ago when I drove a 50 GMC to school, I used to put a piece of cardboard in front of the radiator, but I didn't expect much heat until after a couple of miles. | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | Most of these old rigs hold way more coolant than newer rigs thus takes more time to get all that coolant up to temp., be it 180 or 195.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | |
