6 members (UtahYork, GMJim, Jims46, Danielbolt, Steelonsteel, dt235sd), 162 guests, and 3 robots.
Topics128,167
Posts1,057,017
Members48,458
V
V Offline
I got a new steering mast bearing from Jim Carter and also the horn button retainer that apparently goes on top of it. From what I can tell the steering mast bearing goes in the steering column and is used as a race to house the bearing balls, otherwise why call it a bearing, right? Unfortunately there are no bearing balls in the package it came in. Am I right and are there supposed to be bearing balls in this race that get get held in place by the horn button retainer that sits of top of it and, if so, how many and what diameter of balls? I got this truck in pieces so I don't have what was originally in the top of the steering column. Thanks for any help.
I don't see the mast bearing for pre-46 on Carters site, but if you got something like this, that is the bearing not a 'race', you don't buy an assemble-it-yourself bearing .... if you have something much different you'll need to link a picture for anyone to know what's happening
V
V Offline
Yes, that's the one. Thanks.
I tend to call them "bushings" more than bearing!! I was replacing a "bearing" on a 67 column and while a true bearing is available the vendor sent me a brass "bushing".
Somethings just don't make sense!!
V
V Offline
I agree.
I got mine from Chev's of the 40s. Looks just like the one red58 pointed out. It works just fine.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
