7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible), 34 guests, and 10 robots.
Topics128,012
Posts1,055,312
Members48,419
#920241 02/16/2013 9:32 AM
Want to mount some exterior mirrors on the area between the hood and windshield, both sides (cowl area?), seems like a real tight area to try and drill from the inside out. Is there a template that I can lay over the outside and drill from the outside in, thanks much, HUGH
kahoys #920243 02/16/2013 9:38 AM
What are you working on?
kahoys #920270 02/16/2013 11:07 AM
Its for my 1952 3100 pickup, sorry bout that.
And let me say thanks DADS50 for your help and pictorals in helping me me with my ahooga horn install, really turned out nice, and thanks to you it was easy too.
kahoys #920275 02/16/2013 11:34 AM
Look up under the dash and you'll see reinforcing plates on both sides with holes in them where the mirrors mount. They are the template. You need to at least make a punchmark from the inside to get position correct.
You Tube
kahoys #920283 02/16/2013 12:53 PM
Maybe this will help same offer to you if you want the pattern.
https://www.stovebolt.com/ubbthread...mp;Words=Walt&Search=true#Post914769
kahoys #920286 02/16/2013 1:01 PM
Thanks for your comments,
Yes, there are reinforcement plates under the dash for the mirror fasteners.
Might look something like this from Denny's pics
...Denny's pic...
kahoys #920363 02/16/2013 7:37 PM
The one on the drivers side is HARD TO SEE. There are about 4 holes in the re-enforced piece under the cowl so be sure you used the right ones......I have an extra hole in my cowl!! It was only after I stuck my camera up under the dash and snapped a picture that I understood what I did wrong....listen to Brad and the guys, they are "dead on".
With the glove box out you can see the ones on the right side really well.
...just FYI.
kahoys #920378 02/16/2013 9:05 PM
Was able to feel the two holes on the passengers side, and your right thr drivers side is a bit trickier, seems like there is a stud already in a hole that can only be seen from under the dash,
have not located the second hole as of yet, may try the cell phone camera tomorrow to exactly know what I have under there.
I received the cowl to hole template from Brad, and was hoping to simplify the process by drilling from the top in, but I think for now it might be wiser to remove what needs to be removed allowing me access to those areas and center punch those holes so when drilled they are done right once and for all, thanks go out to Brad Allen for the pictorals and template and to DADS50, Curt B. and Achipmunk for all your help guidance, HUGH
kahoys #920389 02/16/2013 9:52 PM
There could be a broken stud in the hole or bondo if it was filled. On the drivers side you most likely have existing holes plugged with something, LS mirrors were stock, RS mirrors were option 210G for the short bracket. So it most likely has something in it.
