4 members (cmayna, 52Carl, CATMAN, J Lucas), 126 guests, and 2 robots.
Topics128,195
Posts1,057,380
Members48,471
Does anyone know of an adapter to use a 1951 216 oil bath air cleaner on a 1957 235 engine. It looks like I can remove the air cleaner lid mounting stud from the 216 oil filter housing and go straight up from the 235 carb center stud. The problems is that the 216 filter mounting flange is to small to fit on the 235 carb. In looks like the inside diameters of each are the same.
You need to find the carb that matches the air cleaner.
1946 1/2-Ton Chevy
I have the carb that matches the air cleaner but it is not the correct carb for the 1957 235 engine. The 1957 235 car engine did not come with a air cleaner. The 1957 235 car engine had a funky looking low profile side canister oil bath air cleaner for hood clearance.
Won't the smaller 1951 air cleaner restrict the air flow into the larger 1957 carb? headscratch
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The 1951 air cleaner is huge!
Why not just use the correct filter?
what is this 57 235 going in?
57 235 into 1951 1/2 chevy pickup.
Might have to change the top of the carb to a truck version to use the air cleaner you want.
Have your local machine shop make you an adaptor ring.
