| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Without a title here you pay DMV $7.00 to tell you ho was the last registered owner. then you send a registered letter to them asking them to sigh it off. It gets returned with no known forwarding address. Back to DMV. Now they want to look at the truck but the body is off the frame.Here the sheriff will come to your home to verify the ID. I made an appointment and explained the body is off the frame so I cant bring it in. So the sheriff comes buy takes one look and said the body must be on the frame for him to check the Vin# The body is in the garage and the frame is directly in front of the garage door.But that is not good enough. Bill
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That just goes to prove the theory that it's best to have clear title in your name before starting any work.
I hope it all works out for you. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Time to get a lawyer, or send it to the scrap yard.
-W | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | goneagain, at least it sounds like with a little patience you can come out OK but as mentioned above that is definitely a lesson learned for us all. set the cab on it and call him back.....once he ok's it then set it back off!!! Just be glad your not trying to do it in S.C.!!!!!!!!! | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | All is good, there are no numbers on any of these frame's. So it's a non issue.I have a clear title but DMV needs the inspection report before issuing plates. The only ID numbers on the trucks is on a tag on the firewall held on with two screws. I could have just taken it off and played stupid. That's what I get for being honest I guess.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I have a clear title but DMV needs the inspection report before issuing plates. So why do you need plates for it if it's all apart off the frame? I usually transfer title right after the purchase and get the plates when the restoration is complete and it's ready to drive. This saves the $$ of registration and insurance.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have 3-'37 GMC'S, all have the SN stamped on the outside of the frame, right side, just behind the front spring hanger under the grease and rust, big numbers, Chevy's might be different, though.
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I have a clear title but DMV needs the inspection report before issuing plates. So why do you need plates for it if it's all apart off the frame? I usually transfer title right after the purchase and get the plates when the restoration is complete and it's ready to drive. This saves the $$ of registration and insurance. I have only had the Panel three weeks. And you are right I don't need the plates now.They can wait but do want to finish the registration. Thanks Bill
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I've checked both frames and no numbers. Even talked to the Idaho registration expert. So I guess GMC'S are differnt. I have 3-'37 GMC'S, all have the SN stamped on the outside of the frame, right side, just behind the front spring hanger under the grease and rust, big numbers, Chevy's might be different, though. Thanks Bill
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The number on the front of the frame is only on GMCs and they quit doing it sometime in the late '40s I think. | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | As you may or may not know,before 1955 the VIN number was the engine serial number. Once the original engine is gone, the title is no longer valid. The numbers on the cab are production numbers and do not match the title. The frames are not marked or is the cab with the engine number.
I had to have my verified before titleing due to owners mix up and what not with original paper work. Mine is now titled much like a home built trailer with a very long vin number rivited to the door jam.
Good luck with it and don't give up, it can always be worked out .
Joe | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I had to take tater to the Highway Patrol to verify the title ID and the engine number were the same.Luckily the previous owner updated the title when he put the newer 235 in it.
I think I would do what the sheriff asked and call him back.I wouldn't do anymore work until it's in your name.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | The sheriff came out yesterday and made the Numbers on the fire wall tag the new VIN#, I took that to DMV and they gave me my new registration A lot of red tape but all they want is to fill in the blanks. Next time I will just pull the tag off and play stupid.
| | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | Red tape is all they know! Glad it worked out.
Jow | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I know most all states have different laws. But I just cannot believe you guys are having to find original titles for trucks made in the 30's 40's 50's and 60's. Here in the "deep south" Alabama did not even have car titles until the early 70's. You just got a bill of sale. I think it was the same in Ms. Tn. and other southern states. I remember in 1966 I bought a new Hemi-Plymouth, in Ms. and the Dodge dealer only gave you a bill of sale. How would we ever get a title now on something built from the 20's to the 70's ? On my 1957 GMC, all I have to do is take a bill of sale from the guy I got it from, to the "tag office" and they will sell me a tag, even an Antique tag thats good forever. I will also get regestration papers at the time, using only the vin #. Also here in Al. they cannot give you a seat belt ticket, if it did not originally come with belts.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | I've been waiting 9 1/2 months for the title to come back on my '46 that I bought out of GA. I had all the paper work in order. I've been to the DMV countless times. The last time I was there they said it had been printed and should be in the mail in a few days, that was two weeks ago. Back I go again. I hope one of these days the squeaky wheel will finally get some grease. At least I haven't spent any money on it yet, other than the purchase price. The real cute thing is they issued tags and a registration 9 1/2 months ago so I've been driving it like I stole, heck maybe I did, according to them anyway.
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | I guess the Stovebolt gods threw me a bone. Today when I got home the title was in the mail, I should have posted that rant about 8 months ago.
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | The title I get from Boise will be a conditional title for three years to make sure that the last registered owner (that I'm sorry to say passed away in 2002)Doesn't try to claim the rig.
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Well I received the pink slip for the 37 today.HAPPY DAY!
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | In CO, one must have a notarized bill of sale, be inspected only by CHP at special location-last inspection before engine change-found out later, inspections only good for 3 years!
