1 members (Steelonsteel), 141 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#918796 02/10/2013 10:45 AM
whats better for me and my 1958 235 motor, , a 200r4 or turbo 350 tranny, right now i have a cast iron 2 speed,
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #918801 02/10/2013 11:09 AM
All depends on what your expectations are or what are you trying to get towards?
lilrobo #918822 02/10/2013 1:47 PM
i am looking for a driver
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #918832 02/10/2013 2:15 PM
Turbo 350 or a TH700R4, with the 700R4 being the best overall value (better gearing plus an overdrive).
Bill Burmeister
lilrobo #918869 02/10/2013 5:06 PM
i was thinking about a 200r4 ??
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #918878 02/10/2013 5:30 PM
The 700 will easier and cheaper to find, as they were used longer. They're also far stronger in stock form.
Bill Burmeister
lilrobo #918913 02/10/2013 6:47 PM
The 700 is stronger, but the 200 should do ok behind a 235. The overall weight of the truck will be the enemy, not the motor.
The 700 has a lower 1st gear than the 200.
Here's a link with info on most gm automatic transmissions.
http://www.700r4l60e.com/transmission_gm.html
lilrobo #918926 02/10/2013 7:33 PM
....thank you for posting that link bbsdad. I've had a few things on my mind lately and that will answer my questions....AP
lilrobo #918958 02/10/2013 8:44 PM
It would go in my 58 biscayne car i just after a driver no drag
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #919009 02/11/2013 1:43 AM
I would think a 2004R would be a better choice, since it's shorter than a 700R4. You don't have a lot of room to work with, with an X frame under your 58.
Brian
1955.2 3100 Truck
lilrobo #919020 02/11/2013 4:57 AM
Good to here , iam on the look out for a tranny now
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #919506 02/13/2013 4:34 AM
235, your only easy choices are the powerglide, hydramatic, standard or heavy duty 3 speed, 4 speed, they may have offered a 5 speed behind the 6's I'm not sure. You can not easily use a 700R4, there is no way to mount it to the engine less some special parts are made to adapt it. It will not fit a stock 58 chev truck frame either. I don't think a Cast iron pg will either.
lilrobo #919519 02/13/2013 6:47 AM
He is working on a car.
lilrobo #919521 02/13/2013 7:01 AM
The bellhousing on the 235 is different than what's on any TH350, 700R4, 200R4, etc. The driveshaft for your cast iron pg is also longer, so you would need both an adapter and to shorten the driveshaft. It's not just a direct swap unfortunately.
I learned this when I swapped the 235for a 350 in my 62 Bel Air and also had to swap the cast iron power glide.
My 46 GMC on Photobucket
lilrobo #920132 02/15/2013 7:45 PM
Yeah i know, ,, i just dont know what to do, ,,, maybe just leave it alone and just drive it, ,,,
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
