2 members (dunfire, Bills Auto Works), 121 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
b10
Offline
Title just has CHEVY TRUCK no year. How do you find out what year she is? Is the vin number the answer? Does anybody know? (HELP) THANKS
Is there a ID plate on the driver side door jam? May help although that along with an engine could have been changed. Also, look for cab differences between 47-50 and 51 when changes were made,ie, quarter door windows.
Drew
Is the serial number still on the door post?
Can you post pics?
There are other clues such as vent windows, drivers side cowl, how the cab is mounted.
Can you provide more info?
b10
Offline
number stamped into plate 14jp-f 14531 on door jam.door handles are pull down not push button.no side vents just slots that look like gills and( chevrolet)on the side of the hood. the carb has a small air cleaner that has no oil bath.there is a vent you push up from inside the cab below the windshield. it is not a three window only one. was a216 changed to a 235 .
The f does not compute but 14 jp is a Baltimore built 1951. By the way, the automated VIN busters in tech tips no longer work?
b10
Offline
THANK YOU MR ALLEN, Baltimore built. Did not know they had a factory there. I always said it was 52 but they had bush button door handles. Again thank you.
b10, just curious..........do your doors have vent windows or not?? If they do that would also help confirm your truck is a 1951 model.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
b10
Offline
ON 11-27-12 my daughter posted a picture for me on how to post pictures on the Bolt.Betsy has vent windows.the picture is right after we pulled her out of the corner of the garage.
Here is what the VIN buster came up with (working now).
14JPF 14531
Built in June 1951
3100 1/2 ton
116" wheelbase
Baltimore MD Plant
heres your pic from the other thread
Originally Posted by b10
http://i1161.photobucket.com/albums/q502/momanddad15/0911452f.jpg
my daughter got this picture of betsy on line for me.thank you Healing Bear for the help.
