0 members (),
93
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Title just has CHEVY TRUCK no year. How do you find out what year she is? Is the vin number the answer? Does anybody know? (HELP) THANKS | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Is there a ID plate on the driver side door jam? May help although that along with an engine could have been changed. Also, look for cab differences between 47-50 and 51 when changes were made,ie, quarter door windows.
Drew
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is the serial number still on the door post?
Can you post pics?
There are other clues such as vent windows, drivers side cowl, how the cab is mounted.
Can you provide more info? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | number stamped into plate 14jp-f 14531 on door jam.door handles are pull down not push button.no side vents just slots that look like gills and( chevrolet)on the side of the hood. the carb has a small air cleaner that has no oil bath.there is a vent you push up from inside the cab below the windshield. it is not a three window only one. was a216 changed to a 235 . | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The f does not compute but 14 jp is a Baltimore built 1951. By the way, the automated VIN busters in tech tips no longer work? | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | THANK YOU MR ALLEN, Baltimore built. Did not know they had a factory there. I always said it was 52 but they had bush button door handles. Again thank you. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | b10, just curious..........do your doors have vent windows or not?? If they do that would also help confirm your truck is a 1951 model.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | ON 11-27-12 my daughter posted a picture for me on how to post pictures on the Bolt.Betsy has vent windows.the picture is right after we pulled her out of the corner of the garage. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is what the VIN buster came up with (working now). 14JPF 14531 Built in June 1951 3100 1/2 ton 116" wheelbase Baltimore MD Plant | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | heres your pic from the other thread | | |
