1 members (Hotrod Lincoln),
60
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | I have what i was told was a 51 1/2 ton truck . BUt now not sure that it might be a 3/4 ton, as there is no bumper frame bracket on the side of the chassis over the rear axle.And the leaf springs only have 3 leafs.
I have pics to help .
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | my 1/2 ton frame flares out at the back.By that I mean the back is wider than the front.The rear spring mounts are under the frame With a 3/4 ton ,the frame rails are the same front to back.The rear spring mounts are on the outboard side of the frame. I hope this helps | | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | THink i have 3/4 ton then , if you send your e amila illl give you a pic ..
many thanks | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Does the truck still have its data plate? If so run it to see, and yes pictures would allow people here to give you their expert opinions. 3 leafs is not typical of 3600 (or 3100 for that matter which should be 8/8) chassis which should have 8 in front and 7 in the rear. http://www.stovebolt.com/techtips/VIN.htm Here is information to decode your VIN neither of the auto versions are working. | | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | Sorry it does not have a vin data plate .HOw do i get a pic on here ? | | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy wc54, how many nuts hold the wheels on? Can you supply the serial number from the truck? Niether the 1/2 ton or 3/4 ton have springs that only have three leaves. A picture, as they say, would be worth a thousand words. | | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | New on here so i dont know yet how to post a pic .has 6 wheel nuts . The truck has a 57 , 235 engine now .DEf has 3 springs with shocks that have an air line on them | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy wc54, it sounds like you have a hotrodded 51 1/2ton, hope that helps. | | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You have a 1970's version air shock (Gabriel Hijackers nostalgia), from what I can see in the picture you have a 1/2-ton chassis. | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | Since I haven't dealt with very many of these trucks, the only thing I can say is it's 1950+ frame as the shocks are tubular shocks and not the lever action. From what I can tell the shocks look as though they are going into a stock location and aren't aftermarket made brackets. | | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | Thanks for you info guys
Useful Still a bit confused .I have the LMC catalogue . According to their drawings I have the front suspension detail of the 1st series 1/2 ton , but the rear suspension detail of the 3/4 ton. The main difference appears to be the rubber bump stop position . Any way , i have now located a 3/4 ton chassis just 10 miles form me here in england and so intend to swap the 3 leaf springs for the proper 7 leaf set and fit its shocks as well .Will be binning the air shocks! | | |
