| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I am re-building a Braden LU 4 winch with a PTO, which theoretically came from a 1957 Chev. NAPCO. I'm not sure of the exact name, but my question is regarding the rectangular frame with "rollers" that guide the cable during its travel. It seems that the top and bottom "rollers" should rotate. It appears that there is an insert at each end with threads for the holding bolts. I'm not sure if the inserts should rotate inside the rollers. Mine don't, either they are rusted tight or they aren't supposed to rotate inside the roller ends. If anyone has experience with this, any advice would be appreciated. Thanks, don
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I believe it is called a Fairlead.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | My Warn on my Toyota doesn't even have a roller fairlead, just a rectangular attachment hole with rounded edges. I don't know why some have rollers and some don't. I have wire rope in the Warn.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I don't know why some have rollers and some don't. I have wire rope in the Warn. [/quote]
I really has to do with cost. Unless a winch is used a lot and in the same position the fixed rollers work fine especially for the occasional use. On a heavy duty winch they are nearly always found except on a wrecker where the sheeves do the rotating. So the application has much to do with it. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks all. Dave that makes sense. I can continue without worrying about it now. don | | |
