4 members (55shaker, jmoore, Otto Skorzeny, Gdads51), 159 guests, and 3 robots.
Topics128,259
Posts1,058,291
Members48,485
#917586 02/05/2013 9:06 PM
I am re-building a Braden LU 4 winch with a PTO, which theoretically came from a 1957 Chev. NAPCO. I'm not sure of the exact name, but my question is regarding the rectangular frame with "rollers" that guide the cable during its travel. It seems that the top and bottom "rollers" should rotate. It appears that there is an insert at each end with threads for the holding bolts. I'm not sure if the inserts should rotate inside the rollers. Mine don't, either they are rusted tight or they aren't supposed to rotate inside the roller ends. If anyone has experience with this, any advice would be appreciated. Thanks,
don
I believe it is called a Fairlead.
My Blog
My Warn on my Toyota doesn't even have a roller fairlead, just a rectangular attachment hole with rounded edges. I don't know why some have rollers and some don't. I have wire rope in the Warn.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
[/quote]
I really has to do with cost. Unless a winch is used a lot and in the same position the fixed rollers work fine especially for the occasional use. On a heavy duty winch they are nearly always found except on a wrecker where the sheeves do the rotating. So the application has much to do with it.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thanks all. Dave that makes sense. I can continue without worrying about it now.
don
