0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | I got a spare engine out of a 49 chevy truck.. I pulled the head to look at the cylinder walls. All the cylinders look good except for #5. It looks like someething has grown inside of it. It is also all over the valve chamber in the head. Anyone know what this could be? Thanks #5 cylinder
Daniel
1953 Chevrolet 3800 Stepside
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | To me it looks like the cylinder has been full of water | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Seen similar on cracked blocks usually in the middle of the block, look the block over carefully it is most likely a boat anchor. | | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | Yeah that's what I figured. I tried to clean the head up tonite and it is really pitted.. But that makes sense about the cracked block. Brad you are right, it's good boat anchor.
Daniel
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't discount it sitting with a valve having been open and collecting a lot of condensation or some water down the intake - check what it looks like in the pan before you decide block condition .... if you have any real interest in the engine
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What I'm seeing in the picture is an engine block that is badly in need of cleaning. If that was indeed dipped in a hot caustic tank then it was only in long enough to clean the grease of the outside. Who "rebuilt" your engine??? And what I'm seeing in the picture is very heavy rust scale that may have been loosened in some way and is now breaking loose and clogging the water passages. Also as indicated by the color of the water droplets on the deck you have a heavy rust problem in that engine.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Denny certainly has a point, IF the block was also properly hot tanked ..... but my take is just the head was really 'rebuilt' .... also Utah might be blessed with very minerally hard water  Bill | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | My post was slightly misleading (It was right before bed). The two pictures above were taken right after I removed the motor/head from the truck. Both pictures were taken before it went to the machine shop. Unfortunately I did not take any pictures of the disassembled motor after cleaning, however here is a picture of the reassembled motor. Bill you are very correct, Utah does have very high mineral content in the water. Denny the truck had sat for almost 20 years in Nebraska before I got hold of it. I am assuming that is when the rust problem started. I am quite confident however that the rust problem is gone. I had Mike at Ramco Machine do the rebuild/machine work. Here is the disscussion on the rebuild . I am quite happy to say He stuck with his original quote of $1800. Though it did take 3 times longer then originally discussed. Thanks You everyone who lends their knowledge to this site. My truck would be nothing like it is today without the Stovebolt forum! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just a tip Curt or anyone else, about the water that your put in your 'Bolt. I dehumidify my basement in the summer and therefore get gallons of "distiled" every day. I save it in a few old milk jugs and use it for the battery and when I fill the engine. No minerals!
Denny G
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and if you need to its available most places for about a buck a gallon at any drugstore or family grocery store. . I use it for my C-Pap machine and have it around all the time. Right on Denny. | | |
