6 members (Donf, Rustnut, Eisenholtz, TUTS 59, Hotrod Lincoln, 1 invisible), 61 guests, and 3 robots.
Topics128,203
Posts1,057,414
Members48,471
Anyone have a picture of a front sway bar installed on a 49 Pickup that could be posted? Thanks
dougs #916046 01/30/2013 9:39 PM
A photo of an original front sway bar set up from any panel body 1/2 ton truck from 1947-1951 (early 1951) would be what you are looking for.
dougs #916054 01/30/2013 10:07 PM
Thanks very helpful
dougs #916086 01/31/2013 6:00 AM
This is the GM anti-sway bar 1947-1950:
http://www.pbase.com/dennygraham/image/148561503
This is the GM anti-sway bar 1951-1955 1st.:
http://www.pbase.com/dennygraham/image/148561505
This is an after market anti-sway bar from CPP:
http://www.pbase.com/dennygraham/image/113628961
And here are a few pictures of the CPP instalation:
http://www.pbase.com/dennygraham/3604_suspension&page=all
Denny Graham
Somewhere north of Sandwich, IL
Denny G
Sandwich, IL
Denny
Thanks for the pictures. I notice some sway bars attach to front axle and others to the front bottom of the spring u-bolt. Does it depend on the year of the truck or is there a choice. If there is a choice which is the better. Thanks Doug.
dougs #916128 01/31/2013 8:52 AM
dougs #916135 01/31/2013 9:51 AM
Thanks Pictures are good
Are there any new parts made for the factory sway bars,I have the 47 to 50 style and need the parts to attach it to the frame and springs,I know of a 51 to 55 style that is on a panel in a junkyard but the parts that attach it to the axle are severly rusted.
Jeff, if your putting one on the 37 I think Joe H. did this on his 37 but not sure. It'd be worth asking him though. Or it may have been a rear one?? Just adding to the conversation I guess!!
I seen some pictures of the installation but recently came up with the factory part.
So this brings a question to mind, were anti-sway bars avalable
from GM for the art deco's? Or was it a post war option
starting when they released the new Advance Design trucks?
And if so I'd like to see a couple of pictures of one on
a pre-war truck.
Denny G
Denny G
Sandwich, IL
I believe anti-sways were standard on pre-war thru 1946 panel trucks. My '46 looked just like the'47-51 pic.
And Denny, your detail and documentation are mind blowing still.
You've got to write "the BooK".
Tks so I guess they did have them for the earlier trucks and
from what you say it sounds like they were using the same sort
of link that they used on the early AD's.
I'm to dang disorganized to write a book.
Denny G
Denny G
Sandwich, IL
not sure you really need one on AD. email Patrick's and see what he says
Redryder pix
My Hotrod
Maybe I got mixed up here Fred, but we were, talking about anti-sway bars right?.
After I put the one on the front of my '50, 3604 there was a world of difference
in the handling. My "big old wife" was no longer stiff legged and white knuckled when we went around corners or exiting the expressway clover leafs.
For the small cost of the CPP anti-roll bar and the little time it took to install it I'd highly recommend adding one to any AD.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
ODSS President
ODSS President
Denny Graham
Sandwich, IL
Side by side with adding a '62 3sp+od to my '49 AD the front stabilizer bar (I used CPP) the best addition IMHO to one of our old trucks.
~ Cosmo
1949 Chevy Half Ton
