4 members (J Lucas, Wally / Montana, 68ironhead, cmayna), 86 guests, and 3 robots.
Topics128,197
Posts1,057,261
Members48,466
Hello, I have a 1953 3600 and I was just wondering would it be fairly easy to replace a column shift 3 speed transmission be replace with a 4 speed stick shift?
Were they fairly interchangeable back then or is it a can of worms?
Dave
Me and my '53!
No problem switching to an SM420 4-speed with the torque-tube adapter on the back. Same length as the 3-speed. You would need the 4-speed forward u-joint yoke and the 3-speed rear u-joint yoke.
The speedometer drive and driven gears would most likely not give the correct speed. A ratio adapter can be obtained for about $100 or less.
Thanks Tim! Does not sound too bad
Me and my '53!
i have a 4 speed from a 216 from 41-43ish time and wat to put it on a 235 from 54 will it work or what do i need
You need to forget that and find an SM420. They are plentiful and cheap and will bolt right up.
how about drive shaft and rear end then will i have to do anything there?
