| | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | anyone know if and where I could get a bolt in v8 mount setup for my 46 1/2 ton? if there are any vendors who sell them, I think my 216 is doing the old death rattle in the bottom end, and im having a hard time finding a usable 235 for it | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any of the vendors, and probably most local auto parts stores, have universal cross members for that - like this, then you add the correct mounts for the engine you're using Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've used stuff from these guys with good results. You may want to take a look at them. I like several of their motor mounts that work great without a crossmember. Take a look and see what you think. http://www.chassisengineeringinc.com/page11.html | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | chassis engineering would be my choice also....quality products...simple instructions......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | I bought mine from brothers trucks but it looks like it's probably the exact same one American Classic Trucks has just sold by a different vendor. I bought the kit, engine and tranny, in 2010 on a sale price of $112.49, $24.50 for shipping: http://www.brotherstrucks.com/prodinfo.asp?number=CETCS59 I haven't installed the kit yet so I can't actually attest to how good it is but it looks like it's well built. The picture shows it sold already welded piece but it comes in 3 pieces so you can shorten it to fit inside your frame rail, boxed or non boxed. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Classic Performance Parts has a universal engine mount kit for around $80 bucks. I used this on a 50 and 55 Chevy truck frame and it worked great. You cut the cross tube to the width of whatever frame you are using. Then slide the ends over the tube then you bolt it to where you want it on the frome. I cut mine to the width i needed, then attached the mounts to the block and set the engine in where i wanted it then marked drilled for the 2 holes on each end then bolted to the frame pretty easy to do. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | http://www.speedwaymotors.com/S-B-B-B-or-90-Degree-V6-Chevy-Crossmember-Mount,3273.html I used this mount in my 51. a little cutting to fit, weld on the ends and off you go | | |
