5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#914082 01/23/2013 6:29 PM
anyone know if and where I could get a bolt in v8 mount setup for my 46 1/2 ton? if there are any vendors who sell them, I think my 216 is doing the old death rattle in the bottom end, and im having a hard time finding a usable 235 for it
hoozat #914095 01/23/2013 7:02 PM
any of the vendors, and probably most local auto parts stores, have universal cross members for that - like this, then you add the correct mounts for the engine you're using
hoozat #914127 01/23/2013 8:06 PM
I've used stuff from these guys with good results. You may want to take a look at them. I like several of their motor mounts that work great without a crossmember. Take a look and see what you think.
http://www.chassisengineeringinc.com/page11.html
hoozat #914189 01/24/2013 6:27 AM
chassis engineering would be my choice also....quality products...simple instructions......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
hoozat #914206 01/24/2013 7:44 AM
I'll third that on Chassis Engineering!
Pics of their components midway down the page here: http://www.bunchobikes.com/my1929chevy.htm
Pics of the trans cross member on midway down on this page: http://www.bunchobikes.com/1952suburban2.htm
hoozat #914252 01/24/2013 10:48 AM
I bought mine from brothers trucks but it looks like it's probably the exact same one American Classic Trucks has just sold by a different vendor. I bought the kit, engine and tranny, in 2010 on a sale price of $112.49, $24.50 for shipping: http://www.brotherstrucks.com/prodinfo.asp?number=CETCS59 I haven't installed the kit yet so I can't actually attest to how good it is but it looks like it's well built. The picture shows it sold already welded piece but it comes in 3 pieces so you can shorten it to fit inside your frame rail, boxed or non boxed.
Carson Holloway
[email protected]
Truck: 1949 Chevy 3100
hoozat #914658 01/25/2013 7:49 PM
Classic Performance Parts has a universal engine mount kit for around $80 bucks. I used this on a 50 and 55 Chevy truck frame and it worked great. You cut the cross tube to the width of whatever frame you are using. Then slide the ends over the tube then you bolt it to where you want it on the frome. I cut mine to the width i needed, then attached the mounts to the block and set the engine in where i wanted it then marked drilled for the 2 holes on each end then bolted to the frame pretty easy to do.
hoozat #915497 01/28/2013 9:30 PM
http://www.speedwaymotors.com/S-B-B-B-or-90-Degree-V6-Chevy-Crossmember-Mount,3273.html
I used this mount in my 51. a little cutting to fit, weld on the ends and off you go
