Brrrr
place holder
0 members (), 136 guests, and 2 robots.
Topics128,274
Posts1,058,431
Members48,489
#912679 01/18/2013 10:37 AM
I am re- torquing my head bolts - no problem there. But there are six bolts in the head - on the right side of the engine (facing the engine) that go into the head on an angle. What are they and what should they be torqued to?
Thanks-
Tim-o
Six bolts or six bolt holes?
Drew
Riding in the Passing Lane
They are not bolts. They are plugs. The holes are used for air injection for emission control.
1972 Chevy c10 Cheyenne Super
Thought that too. That's why I asked.
Drew
Ah ha!! 1966 Chevrolet Truck Service Manual page 6T-3. Air injector reactor system air manifold assembly goes there! Wrench bender and Drew-P you're a couple of smarties!!! I guess I better not torque them to 95 pounds! Thanks! Tim-o
Be very careful with the left front head bolt. You can snap the corner of the block right off. Reread the manual and make sure its not less at the four corners. I have a block here with the corner broke from being to tight.
Joe
Joe
Yes. The specks generally show 85 lbs. on the left front bolt.
Tim- I don't want to take over your post but since you have the attention of a couple of knowledgable 250 guys here who answered your question - I got one for them(and you).....What carb would you run on this engine?
....David
Stock engine ? Run stock carb. It'll be the most efficient for mpg.
Drew
They used the Roch. model B from 63-67 & went to the Monojet in 68. I would run a monojet on any of them for best mileage & Adjustability. The model B works good though.
