0 members (),
133
Mod | | | Forums66 Topics128,284 Posts1,058,526 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | I recently purchased a complete drive train from what was a 1937 1/2 ton that worked for the National forest Fire department. It had overload springs on it.
I have a 1937 GMC half ton. It has the same rear axle and springs. I was thinking of putting the overloads on my 37.
I have the orriginal parts book for 1937 GMC and they don't show that the overload or "auxillary" spring was even availabel on a half ton GMC.
Does anyone here have the 1937 parts book for Chevy that they can look at and see if it lists the overload spring as an option from the factory.
I'm trying to figure out if I was a farmer in 1937 if I could have ordered these springs from the dealer. Also curious why my book shows nothing?
Thanks. Dan
Trombones Totem Poles And Old Trucks!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | back then you could get about anything, including aftermarket .... I see a variety of springs in the master parts catalog that could be what you have, including a "2 stage" set .... need to count the leaves Bill | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I have a '38 GMC 1/2 ton that has over load springs on it
1938 Gmc 1/2 ton
| | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Do you like them? Are they noisy when you go over bumps?
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ...a 37 my nephew and I restored also had the overloads. One thing for sure it was a stiff set up for a 1/2 ton truck. | | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | I've decided not to use them.
| | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | My 37 had them too and could not find anything about them,all my sales literature only mentions them on the 1 1/2 tons. I think they could have came from the factory since on one part it has GC stamped on it,I put a later rear end in it so I did not put them back on and keeping then for parts when I need leaves for the front springs. | | |
