4 members (klhansen, Hotrod Lincoln, 55shaker, UtahYork), 101 guests, and 3 robots.
Topics128,101
Posts1,056,523
Members48,448
Ever since I received my truck (in pieces), I have wondered about the coil connection to the distributor.
Mine had a piece of bathtub rubber stopper between the wire from the coil and the side of the distributor:
http://i1195.photobucket.com/albums/aa397/fourbrads/57%20chevy/IMG_1219_zps60f553f3.jpg
I added a rubber grommet when I cleaned up the engine bay a bit, but always wondered if this wire to the points required isolation from the distributor, which is, I assume, grounded to the block.
Can I delete the makeshift grommet? I am having trouble keeping the wire tight there and the pictures I see on some parts vendors sites don't seem to have a grommet or washer there.
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
yes, it needs to be isolated from ground - that's some PO's makeshift repair for the correct isolator piece, there's originally a square-ish hard rubber plug in that hole with a built in stud that's threaded on both sides of the case - sort of shown in the manual - I don't think any vendor offers the terminal, but you should try to find one
Thanks, Bill. That's just what I needed.
I will have to try to find something similar because how it's "engineered" right now is not working.
Appreciate the fast reply.
Jim
235, 3-speed w/OD
I just noticed your post so sorry for the late response, but I recently picked up both the inner and outer piece from Obsolete Chevy. It's called either a Distributor Terminal Stud bushing or a Distributor shield. I talked to Helen there and she sold me both pieces.
http://www.parts123.com/PartFrame.a...com&TITLE=Obsolete_Chevrolet_Part_Co
1956 Apache
1959 Apache
1966 DeVille
Thanks RayFischer!
I will call them tomorrow.
Jim
235, 3-speed w/OD
