| | | Forums66 Topics128,102 Posts1,056,532 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Ever since I received my truck (in pieces), I have wondered about the coil connection to the distributor. Mine had a piece of bathtub rubber stopper between the wire from the coil and the side of the distributor: http://i1195.photobucket.com/albums/aa397/fourbrads/57%20chevy/IMG_1219_zps60f553f3.jpgI added a rubber grommet when I cleaned up the engine bay a bit, but always wondered if this wire to the points required isolation from the distributor, which is, I assume, grounded to the block. Can I delete the makeshift grommet? I am having trouble keeping the wire tight there and the pictures I see on some parts vendors sites don't seem to have a grommet or washer there. Thanks, Jim | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, it needs to be isolated from ground - that's some PO's makeshift repair for the correct isolator piece, there's originally a square-ish hard rubber plug in that hole with a built in stud that's threaded on both sides of the case - sort of shown in the manual - I don't think any vendor offers the terminal, but you should try to find one Bill | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Thanks, Bill. That's just what I needed.
I will have to try to find something similar because how it's "engineered" right now is not working.
Appreciate the fast reply.
Jim | | | | | Joined: Apr 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 55 | I just noticed your post so sorry for the late response, but I recently picked up both the inner and outer piece from Obsolete Chevy. It's called either a Distributor Terminal Stud bushing or a Distributor shield. I talked to Helen there and she sold me both pieces. http://www.parts123.com/PartFrame.a...com&TITLE=Obsolete_Chevrolet_Part_Co
1956 Apache 1959 Apache 1966 DeVille
| | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Thanks RayFischer!
I will call them tomorrow.
Jim | | |
