4 members (Bill Hanlon, Chip O, walter74, Gdads51), 180 guests, and 2 robots.
Topics128,039
Posts1,055,591
#909942 01/08/2013 10:49 PM
1 Offline
I was looking for the tape or material that holds the wind wing into the channel. I replaced the seals on both and want to reset the new glass.
Thanks Jeff
called glass setting tape, should be available at a local auto glass shop in various thicknesses or at most of the repro vendors
Careful if you order any tape. Some places have two thickness.
1 Offline
Thanks guys, tried the A/P store knew nothing of it. I'll try a glass shop. Jeff
Jim Carter has the right stuff ....
Warm the setting tape up a little (100-120 or so) before you start wrestling the glass back in. It'll squish real nice.... then just razor off the excess.
1 Offline
Good idea on warming it up, where would I find Jim Carter? Thanks Jeff
1 Offline
Thank You! Jeff
