| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | I was looking for the tape or material that holds the wind wing into the channel. I replaced the seals on both and want to reset the new glass. Thanks Jeff | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | called glass setting tape, should be available at a local auto glass shop in various thicknesses or at most of the repro vendors
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Careful if you order any tape. Some places have two thickness. | | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | Thanks guys, tried the A/P store knew nothing of it. I'll try a glass shop. Jeff | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Jim Carter has the right stuff ....
Warm the setting tape up a little (100-120 or so) before you start wrestling the glass back in. It'll squish real nice.... then just razor off the excess.
| | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | Good idea on warming it up, where would I find Jim Carter? Thanks Jeff | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Jul 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 23 | | | |
