| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | My 216 is cracked and patch is got to be re done.What type is a replacement and what would the cost be ball park.What would I look for in a local junk yard? Thanks....Paul | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What do you want or expect out of the next engine?
You may consider a free to cheap 216, a later model 235, better yet a 261, or any number of engines further and further from stock.
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | You can also get a 292...one of the larger inline 6's. I think you can still find them sometimes in salvage yards, as they were used until the 70's. Cost is going to entirely depend on what you find.
If you have to rebuild it, then it will probably cost a bit more than your typical V8. But I'll bet you can get it rebuilt for 3 to 4 grand, depending on your machinist.
You can rebuild a small block V8 for less, so your cheapest option might be to convert it to a V8. But that's a personal choice. You can rebuild a V8 for less than 2 grand if it's just a stock rebuild.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Paul, do a LOT of homework before you jump. I would suggest nothing short of at least a 235 but there are others out there. When you decide what you want check and see what a Remanufactured engine would cost from some of the Vendors like NAPA, even Auto Zone and Advance. You may be surprised and if you can get a discount it would be a good option.
....now, down in Johnson S.C. there ia place that actually does the remanufactured engines that NAPA and some others sell. Just recently my nephew went to rebuild an engine but after "running the numbers" it was several hundred dollars cheaper to let the folks down there rebuild....YOUR OWN ENGINE if thats what you want. Therefore, if you could find a decent rebuildable 235, 261, or V8's for cheap, then have it rebuilt. There are ways to save some money and still come out with a nice engine.
If you want the address or number I can get the info from my nephew. Just send me a PM. | | |
