| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Hi guys, well I got the brakes all done except hooking up the vacuum and fresh air lines to the HV. I have the clutch installed and getting the driveline in. It seems I am missing the metal clamp that holds the carrier bearing to the chassis. Maybe I misplaced it?? Is there a place that sells just the clamp or do I need to get a whole new bearing? Anyone know a part number for either or both? And I am assuming the bearing is pressed on to the driveline?? Anyway, just getting those 2 things done should allow me to drive the bus, FINALLY. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Looks like a replacement carrier bearing, I haven't seen the strap sold separately but you can get the whole thing new easy enough.
Grigg | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Yes the whole assembly isn't real expensive, just a matter of getting the right part number. Suggestions on where I could find that? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Take the old one with you to NAPA. | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Mine was $17 and change at NAPA | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | I stopped in there today and there are 4 different options for my bus. So I need to get the bearing off the shaft and just get it in there as Grigg suggests. Thanks again all.
Fred | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | A better fix was to go to Drivelines NW and he looked at the bearing and said it was fine. Went to the back and brought out the right support bracket for me and said have a nice evening. So looks like I'm getting to installe the driveline tomorrow. Yay!!
Oops, guess I wasn't logged in when I posted. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | You can't beat that with a stick. I will be looking forward to seeing video of the first drive!!!!!
