5 members (Hotrod Lincoln, Hanks custodian, Otto Skorzeny, Woodcmiami, 1 invisible), 145 guests, and 7 robots.
Topics128,077
Posts1,056,031
Members48,433
#909465 01/07/2013 12:40 PM
Hi guys, well I got the brakes all done except hooking up the vacuum and fresh air lines to the HV. I have the clutch installed and getting the driveline in. It seems I am missing the metal clamp that holds the carrier bearing to the chassis. Maybe I misplaced it?? Is there a place that sells just the clamp or do I need to get a whole new bearing? Anyone know a part number for either or both? And I am assuming the bearing is pressed on to the driveline?? Anyway, just getting those 2 things done should allow me to drive the bus, FINALLY.
1956 Chevy School Bus Superior Body
3B Offline
Hy fclaridge, click on the link and identify which part you are missing, then I'll try and find you a part number.
http://i120.photobucket.com/albums/o178/pintos4me/CarrierBearing_zps70f492dd.jpg
fclaridge #909644 01/07/2013 10:41 PM
I looked at that picture and it would be the 5.432, but I don't have that kind of support. Mine has a D shape rubber cushion surrounding the bearing.
[IMG]http://i107.photobucket.com/albums/...E-633DBED53EEC-1146-000001192BC501EF.jpg[/IMG]
[IMG]http://i107.photobucket.com/albums/...D-0A87783DBAFB-1146-000001194E753EB4.jpg[/IMG]
Here is a possibility of what a new one looks like??
[IMG]http://i107.photobucket.com/albums/...C-1601B75F2261-1146-0000011B666AA932.jpg[/IMG]
Looks like a replacement carrier bearing, I haven't seen the strap sold separately but you can get the whole thing new easy enough.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Yes the whole assembly isn't real expensive, just a matter of getting the right part number. Suggestions on where I could find that?
Take the old one with you to NAPA.
Mine was $17 and change at NAPA
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
I stopped in there today and there are 4 different options for my bus. So I need to get the bearing off the shaft and just get it in there as Grigg suggests. Thanks again all.
Fred
A better fix was to go to Drivelines NW and he looked at the bearing and said it was fine. Went to the back and brought out the right support bracket for me and said have a nice evening. So looks like I'm getting to installe the driveline tomorrow. Yay!!
Oops, guess I wasn't logged in when I posted.
You can't beat that with a stick. I will be looking forward to seeing video of the first drive!!!!!
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
