0 members (), 120 guests, and 4 robots.
Topics128,184
Posts1,057,266
Members48,467
1 Offline
After painting, is it easier to install the front inner fenders attached to the fenders or can they be installed from underneath after the fenders are on? The size and clumzyness of the 2 together seems like a lot at once.
Install the inner fenders first, than bolt on fenders.
Drew
1 Offline
and the inner fenders only bolt to the fenders and rad support, correct?
What year are we talking about? On my '51, the inners bolt to the firewall and the radiator support. Then I can slip the outter fenders on.
That's what I was thinking. Did that on my '50/'51 combo.
Shoulda asked his truck year first.
Drew
Don't forget to pick up some of those pointy body bolts when you reassemble. When you are trying to line up holes on the inner fenders, outer fenders and radiator support they help keep the swearing to a minimum.
1 Offline
yes guys mine is a 50. I didnt think there were mounting holes on the back of them. Will take another look thanks!
Baba (or, anyone else who knows),
What is the name of that style of bolt? I need them for COE floor panels. They are nice for lining up panels.
Tim, Take a look at this link.
http://www.auveco.com/product/body.html
Don,
Thank you very much.
Great Discussion and Information, Guys! I'm glad 1965t5 asked his Question, because I'm getting ready to mount the fenders, radiator, grill, etc on the Blue Funk!
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
the passenger inner fender bolts to the firewall/toeboard
...click...
the drivers inner fender bolt the the parking brake bracket
...pic...
...pic...
and inner fenders bolts to rad support
...pic...
...pic...
...pic...
I had no problem installing them as an assembly by myself. but the other method may be better
don't forget your anti squeak material
I mounted my inners first as well. My advice leave everything loose until you get all bolts in. It looks sometimes like it will never all work (especially if you are putting in a repop grill), but it does.
http://www.flickr.com/photos/advance-design_parts_co/8129049447/in/set-72157631867396207
