3 members (klhansen, dt235sd, 1 invisible),
67
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | I asked this once before without much of a reply... How do you replicate the rivets in the hood that hold the 2 halves together? Normal rivets don't, as I have 1/4 rivets. I need to replace 3. The rest of the rivets are there. Thanks | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Rivets come in 1/4". You need the tool to install them. The little handheld gun can work but the air riveter or the large, two handed tool works better. Most of the time, I replace rivets with a machine screw and a nylok or a stover. | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | What kind of rivets are they though? They have the solid domed head on them, so they're not the typcial ones I have used with the pin that pops off. | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | They sound like a semi-tubular rivet which requires a setting tool. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Your handle suggests that you have a ’65 but the question you’re asking seems to be about an AD split hood. The hardware store “pop” rivets are for the home owner, backyard tinkerer or the quick and dirty assembly of parts. The rivets used by the factory were Truss-head semi-tubular rivets that need to set as Mr. Smith indicated. Here is a source for those types of rivets: http://www.rivetsinstock.com/rivets/semitubular-rivets.html They are set using a rivet squeezer either manual or pneumatic. Here are some pictures of a manual squeezer being used to assemble an AD grill with the original rivet, which are very similar to the ones used in the hood. http://www.pbase.com/dennygraham/image/138235065 http://www.pbase.com/dennygraham/image/138235175 Denny Graham Somewhere north of Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Denny, great link to the rivets. I personally need some jack rivets if my local restoration pal doesn't come thru for me. Thank You....I had been looking at Graner ect but like this one best. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've bought a lot of, in fact most of my rivets from Jay-Cee over the years Alvin. They are easy to deal with and have about the best stock around. My goal when I start a restoration project is to finish it so you can't tell my work from the factory work. Using the correct replacement rivets helps accomplish that as you can see from the grill pictures. Denny Graham Somewhere north of Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | I asked this once before without much of a reply... How do you replicate the rivets in the hood that hold the 2 halves together? Normal rivets don't, as I have 1/4 rivets. I need to replace 3. The rest of the rivets are there. Thanks Perhaps you should put what year/model truck you are asking about, in your topic? Also, more information within the post itself generally helps as well. This site covers GM trucks made from 1916-1972. Help us, help you. -W | | | | | Joined: Nov 2014 Posts: 15 New Guy | | New Guy Joined: Nov 2014 Posts: 15 | I am clueless about rivets and have read as much as I can but I can't figure out the specific size of rivets I would need to put the two halves of the hood together on my chevy 1951 1 Ton.
Looked at the rivetsinstock.com website but need specific size, etc.
Also, what tool and dies are needed for these rivets? Are all sheet metal rivets the same size on this truck?
I am beginning the work on this truck and a beginner in this process with very limited knowledge (have the manuals, etc).
Thanks for any help.
James | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Great information. I like that better than using pop rivets or machine screws. Like Denny said, don't want to know where I picked up and the factory left off.
With that being said, I'm with J_Wade in being curious what size/length rivet would be needed for the hood and the grill. I'm a long way from being to that point, but I am in the information gathering point in the process.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You will need a variety of rivets if you're going to try and put the truck back together as it was from the factory. To hard to call them out for each and every place. Here are some of the rivets that I've used on projects over the years: http://www.pbase.com/dennygraham/image/159041537/largeUse the charts at Jay-Cee to find your length depending on the thickness that you need to trap: http://www.rivetsinstock.com/rivets/semitubular-rivets.htmlDG
