2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | Hello, I just started dismantling my 216 out of my 1950 3/4 ton I did have the engine running before I pulled it and compression was good in all cylinders ( I can't find the numbers but they were all within limits. All the cylinders look great except for #4 the wrist pin was loose and scored both sides of the cylinder I'm not sure how deep they are . I believe the original size pistons are installed the only marks on the top are the letter T and the piston position number.
What is the Max overbore I can go? Can you sleeve these engines Any suggestions on measuring the damage to see how deep the grooves are
Thank John
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Here's the Engine Spec's from manual for comparisons and starters. Are you SURE it's the original engine? and this is how you measure to find out...
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You can easily go .040-.060. Some 235's have been bored to.100+ but it isn't advisable. Not a problem at all to clean up a scored wall on most engines unless it's really bad. Stock pistons were offered up to .040. | | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | No I'm not sure if the engine is the original The engine code is HAA364772. Hopefully I can get a inside micrometer and see how deep the grooves are but they are pretty deep.
| | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | HAA is a '50 Standard Car Engine (216) made in Flint serial no. http://chevy.oldcarmanualproject.com/chevyresto/5008.htmEgge and some other vendors offer 216 & 235 pistons and rings as large as .100 overbore.
Professional Novice
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Just have a sleeve put in the one hole. And then just put it back together! Just my 2 cents worth. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Oct 2010 Posts: 44 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 44 | Dumb question where do I get the sleeves I live just south of Chicago can anyone recommend a machine shop? Thanks
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | The machine shop that does the work will have or can get the sleeve. They'll have to bore the cylinder out some to allow the sleeve to be installed. | | |
