0 members (), 134 guests, and 4 robots.
Topics128,193
Posts1,057,258
Members48,466
Hello,
I just started dismantling my 216 out of my 1950 3/4 ton
I did have the engine running before I pulled it and compression was good in all cylinders ( I can't find the numbers but they were all within limits.
All the cylinders look great except for #4 the wrist pin was loose and scored both sides of the cylinder I'm not sure how deep they are .
I believe the original size pistons are installed the only marks on the top are the letter T and the piston position number.
What is the Max overbore I can go?
Can you sleeve these engines
Any suggestions on measuring the damage to see how deep the grooves are
Thank John
Here's the Engine Spec's from manual for comparisons and starters. Are you SURE it's the original engine? and this is how you measure to find out...
Give me ambiguity
or give me something else
You can easily go .040-.060. Some 235's have been bored to.100+ but it isn't advisable. Not a problem at all to clean up a scored wall on most engines unless it's really bad. Stock pistons were offered up to .040.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
No I'm not sure if the engine is the original
The engine code is HAA364772.
Hopefully I can get a inside micrometer and see how deep the grooves are but they are pretty deep.
HAA is a '50 Standard Car Engine (216) made in Flint serial no.
http://chevy.oldcarmanualproject.com/chevyresto/5008.htm
Egge and some other vendors offer 216 & 235 pistons and rings as large as .100 overbore.
Professional Novice
Just have a sleeve put in the one hole. And then just put it back together! Just my 2 cents worth.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Dumb question where do I get the sleeves
I live just south of Chicago can anyone recommend a machine shop?
The machine shop that does the work will have or can get the sleeve. They'll have to bore the cylinder out some to allow the sleeve to be installed.
