0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Greetings...
Here is the final result of the restoration I just completed on my Curtis 80-gallon, 3-cylinder, 2-stage, 5HP air compressor.
I bought it on Craiglist for $75 and it had a 3-phase motor and a bad high pressure cylinder wrist pin causing a knock. A new Baldor 5 HP L1430T motor, complete overhaul of the pump, new electricals and a host of specialty features and it is running and running smooth and slow...around 968 rpm.
The specs are 17.4 SFCM @ 175 psi. It pumps great and is quite quiet even for a 3-cylinder "Y" configuration.
Though operational, next on deck is a custom motor sheave & pump pulley cover...to cover the drive belts and pulleys and a 2-stage air cooling stsyem that will go between the output of the high pressure cylinder and the input check valve on the tank...
Burgie
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
...and here it is running until it stops at 175 psi...
Burgie
Nice work!!
Moderated by  MNSmith
