8 members (57 Drifter, Bill Hanlon, 3B, Gdads51, Otto Skorzeny, Gray_Ghost, DennisM, rick46ia),
45
Mod | | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | OK, had a small leak, about 1/2 in. Didn't drill crack like I should have,soooo it grue to 8in.NOW I drilled it gouged it sand blasted it, wire brushed it, degreased it,(did I menshion I had put Gunk Stop leak in it 2 weeks ago?). It's located just in front of the rear drain cock, and lower. Just a head of the oil line. JB went on nice, I warmed the block with a heat gun.CAN'T get all the water out.Keeps weeping out. Tryed air and even a squirt bottle pump.Slow leak now tryed anotyed round of JB. Any Ideas????.....Paul | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Get yourself the stitch kit and fix it or find someone else to do it. You drill a hole, tap it and install a plug. You do this the entire length of the crack to stitch it up. It takes some patience to do it but does work good. | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | Don did not mention that when you drill each hole, they must over lap the previous hole and the plugs should be solid with the square part sticking out so you can grind them off flush. Cast iron plugs would be even better.
Other then this method, welding is your other choice. A good welder might be able to fix it with cast iron rods.
Joe | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I don't know nuttin from nuttin, but would it be possible to pull a vacuum on it to help draw the moisture back into the block and away from the crack? I wonder if that might help while the JB Weld cures? Maybe using a shop vac or a small vacuum pump? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Maybe see if the next lunar event that causes those "King Tides" will pull that moisture away from those cracks and then use a vacum cleaner AND some compressed air to pull and push at the same time... Who would want to take the time to do all that drilling and tapping? Just wait... Those tides will come around again!
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I had good luck using Marine-Tex rather than J-B weld on a crack in a Pontiac straight 6 block. It is a two part epoxy like J-B but seems to tolerate moisture better. I have pictures that show the still seeping crack, the repair, and one a year or so later that shows no leakage. The crack was over a foot long. Marine-Tex is very expensive so if there is a boat repair or Corvette shop near you they will sell you a couple of spoonfulls which is enough for the job. Just don't get it till your READY to use it.
Evan
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..park the truck on a hill leaning the truck favorably to send water in the other direction. Then heat and dry it. | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Jack stands!...Thanks, Paul | | | | | Joined: Dec 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 35 | Had similiar issue. Tried adding a few added to the radiator,waterglass,and a few othrers, none worked and had to flush the system a number of times to try and remove it all. Will never us those things again. Used an AB 2 part epoxy by Moroso sold by Summit and it worked fine.I removed the manifolds and ground it clean, heated with a gun, applied and heated again to help cure. Area must be super clean or it won't hold.
'57 3200
