2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#905065 12/20/2012 5:13 PM
Every one talks about all the different ways to weld a block but nobody ever says anything about brazing. Any thought on this.PS I'm a retired welder and know about cast welding, and brazing. I would like to do it in place, drilling and stoping the crack,(it went from 1 in, to @7in). I'm in the pressoss of rebuilding a 235 for my 3600.....Thanks Paul
I know that brazing a crack in cast iron was common years ago. I think that with new technology other methods have become more popular. I know that my Dad had a Model A that the cylinder head was cracked and had been brazed more than once over the years. It still holds to this day so I don't doubt that it can be done successfully.
Thanks for a quick reply, thats my thoughts also.I'll wate and see if the world comes to a end tomarrow if not then I'll try. If it ends I'll wate a little longer..........Paul
I gas welded a final drive case on a good sized bulldozer and it held and that thing was under a lot of stress.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
