| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Every one talks about all the different ways to weld a block but nobody ever says anything about brazing. Any thought on this.PS I'm a retired welder and know about cast welding, and brazing. I would like to do it in place, drilling and stoping the crack,(it went from 1 in, to @7in). I'm in the pressoss of rebuilding a 235 for my 3600.....Thanks Paul | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I know that brazing a crack in cast iron was common years ago. I think that with new technology other methods have become more popular. I know that my Dad had a Model A that the cylinder head was cracked and had been brazed more than once over the years. It still holds to this day so I don't doubt that it can be done successfully. | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Thanks for a quick reply, thats my thoughts also.I'll wate and see if the world comes to a end tomarrow if not then I'll try. If it ends I'll wate a little longer..........Paul | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I gas welded a final drive case on a good sized bulldozer and it held and that thing was under a lot of stress. | | |
