5 members (Jon G, Otto Skorzeny, Hanks custodian, dt235sd, 3800GUY), 166 guests, and 1 robot.
Topics128,105
Posts1,056,205
Members48,436
#904254 12/17/2012 5:52 PM
Can anyone explain how the 216 on the ton & half is governed?
Would raising the RPM range to that of a car or light truck, get me closer to 55mph? Running 48 @ 2900 now.
3200 rpm would be close to 55 mph.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
My 38 is not governed, I don't know if it was removed or just never had one. It was able to keep up with traffic when I had it tagged if I was willing to push it that hard.
1 Offline
I don't think any of the old Bolts are governed Gric, it's your limitation based on your rear gear ratio and RPM of the emgine.
1936 Chevrolet 1.5-ton SWB
"Murtahg"
More pix on Photobucket
It's only original once.
Governers were optiomnal starting in 1935 (if I remember correctly).
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
The reason I ask is, I'm not sure if its governed or not. The 38 specification manual says the 1.5 ton is governed. I bought the truck from a friend who wasn't driven it in 8 years. The RPM and speed info comes from him. Upon closer inspection, I see it has a Tilltson carb also.
larger trucks were likely to have governors - if you have one it should be obvious, an odd looking thing pancaked between the carb base and the manifold ... regardless if you have one or not, keeping the revs below 3000 would be advisable
