Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Rich'sToys, Dakota Bob), 144 guests, and 3 robots.
Topics128,283
Posts1,058,505
Members48,490
I've been trying to remove the steering wheel from my 54 Chevy COE and it doesn't budge. Any suggestions?
..on many ocassions I simply slide down in the seat, put my knee's up and under the steering wheel where I can put upward pressure on it and then, with the nut on the shaft to help preserve the threads I let someone give it a good whack with a hammer. In most cases it pops up..... a little kroil or other penetrating oil on the shaft will help.
...if the 54 has the holes to use a "puller" then go get a loaner tool from Autozone or Advance. You get the deposit back when you return it. Good luck.
Alvin's knees and hammer-jolt technique often works. Just make sure that you put your knee-pressure near the center. You might crack the wheel if you put too much pressure towards the outside.
I usually use this type of puller. As Alvin posted, it can be borrowed from many parts stores. There are threaded holes in the top center of the steering wheel.
real easy to make a steering wheel puller
I installed a reproduction center horn button on my '54. Now, I can't get it out to remove my steering wheel. Any suggestions on removing the button - other than destroying it while prying out? (They don't cost much, so that's probably what I'll do.)
- Lonnie
My '54 3104
Ex Hall Monitor
Ex Hall Monitor
I've used the knees under the wheel trick many times. These days I use a universal puller with "J" bolts from the hardware store instead of the threaded bolts that come with the puller. I hook the "J" bolts under the spokes of the wheel, put a bit of tension on the wheel then give the center bolt of the puller a moderate tap with a hammer and it pops right off.
This is the type of puller I use.
As Red posted, the outer two bolts should thread into a couple of #10-24? holes in the steering wheel hub, under the horn button
....David
Moderated by  ndkid275, Phak1
