1 members (UtahYork),
114
0
Mod | | | Forums66 Topics128,274 Posts1,058,430 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 10 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 10 | I've been trying to remove the steering wheel from my 54 Chevy COE and it doesn't budge. Any suggestions?
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ..on many ocassions I simply slide down in the seat, put my knee's up and under the steering wheel where I can put upward pressure on it and then, with the nut on the shaft to help preserve the threads I let someone give it a good whack with a hammer. In most cases it pops up..... a little kroil or other penetrating oil on the shaft will help. ...if the 54 has the holes to use a "puller" then go get a loaner tool from Autozone or Advance. You get the deposit back when you return it. Good luck. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Alvin's knees and hammer-jolt technique often works. Just make sure that you put your knee-pressure near the center. You might crack the wheel if you put too much pressure towards the outside. I usually use this type of puller. As Alvin posted, it can be borrowed from many parts stores. There are threaded holes in the top center of the steering wheel. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | real easy to make a steering wheel pullerBill | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I installed a reproduction center horn button on my '54. Now, I can't get it out to remove my steering wheel. Any suggestions on removing the button - other than destroying it while prying out? (They don't cost much, so that's probably what I'll do.)
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | I've been trying to remove the steering wheel from my 54 Chevy COE and it doesn't budge. Any suggestions? I've used the knees under the wheel trick many times. These days I use a universal puller with "J" bolts from the hardware store instead of the threaded bolts that come with the puller. I hook the "J" bolts under the spokes of the wheel, put a bit of tension on the wheel then give the center bolt of the puller a moderate tap with a hammer and it pops right off. This is the type of puller I use.
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | As Red posted, the outer two bolts should thread into a couple of #10-24? holes in the steering wheel hub, under the horn button
....David
