1 members (keithfielder),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2001 Posts: 31 | Does anyone know if the torque tube length from a 51 truck is the same or longer that a 37 truck? What other challenges are there as far a mounting when placing a 51 rear under a 37 truck?
Thanks for the help!
Mike j
Mike J 37 GMC
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I have put a 51 rear under a 40 one ton GMC. I think you need to check the master parts book (can be found online) to double check, but I think the TT will need to be shortened. The other issue can be spline count on the input shaft versus the transmission. That can be easily overcome by using 2 u-joints and making them into one with two differnet spline counts on a given end.
To further help, is this truck short or long bed? What is your transmission?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2001 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2001 Posts: 31 | Short bed.
3 spd 37 trans.
I need to find the parts to make the u joint with the two different splines.
Mike J.
Mike J 37 GMC
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I need to find the parts to make the u joint with the two different splines. I addressed this in a private message to you that you have not read.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I'm curious as to why you want to make this change? What are you trying to accomplish?
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2001 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2001 Posts: 31 | My understanding is that I can't upgrade the 37 rear to the 3.55 gears.
Mike J.
Mike J 37 GMC
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Yes, Sir, but I'm not sure that a 51 truck has a 3:55 geared rear end. A 51 car with a Power Glide rear axle would be a 3:55 gear, but I think the truck is a 4:11. I could be wrong.....
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I believe he is looking into using Patrick's 3.55 conversion for 1/2 ton trucks.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2001 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2001 Posts: 31 | Yes I am.
I have not been able to locate a 49 to 54 powergluide car rear. It seems like the next logical step is to find one to upgrade.
I am between upgrading the rear and doing a T5 swap. That would however significantly change my otherwise stock truck.
It seems many have done the rear upgrade only to later change to a T5. Any experience on this would be appreciated.
Mike J 37 GMC
