3 members (Hotrod Lincoln, Steve_H, 1 invisible), 139 guests, and 3 robots.
Topics128,149
Posts1,056,814
Members48,454
#903247 12/13/2012 9:12 AM
Does anyone know if the torque tube length from a 51 truck is the same or longer that a 37 truck? What other challenges are there as far a mounting when placing a 51 rear under a 37 truck?
Thanks for the help!
Mike j
Mike J 37 GMC
ODSS Lawman
ODSS Lawman
I have put a 51 rear under a 40 one ton GMC. I think you need to check the master parts book (can be found online) to double check, but I think the TT will need to be shortened. The other issue can be spline count on the input shaft versus the transmission. That can be easily overcome by using 2 u-joints and making them into one with two differnet spline counts on a given end.
To further help, is this truck short or long bed? What is your transmission?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Short bed.
3 spd 37 trans.
I need to find the parts to make the u joint with the two different splines.
Mike J.
Mike J 37 GMC
I addressed this in a private message to you that you have not read.
My Blog
I'm curious as to why you want to make this change? What are you trying to accomplish?
My understanding is that I can't upgrade the 37 rear to the 3.55 gears.
Mike J.
Mike J 37 GMC
Yes, Sir, but I'm not sure that a 51 truck has a 3:55 geared rear end. A 51 car with a Power Glide rear axle would be a 3:55 gear, but I think the truck is a 4:11. I could be wrong.....
I believe he is looking into using Patrick's 3.55 conversion for 1/2 ton trucks.
My Blog
Yes I am.
I have not been able to locate a 49 to 54 powergluide car rear. It seems like the next logical step is to find one to upgrade.
I am between upgrading the rear and doing a T5 swap. That would however significantly change my otherwise stock truck.
It seems many have done the rear upgrade only to later change to a T5. Any experience on this would be appreciated.
Mike J 37 GMC
